Measurement Studio for VC++
Measurement studio expired first day I install
HI IM IN VENEZUELA IM USING XP SPANISH VERSION .. VS2010. ANG GET THE SAME PROBLEM OF THE GUY ABOVE.. I CHANGED THE SETTING IN THE LANGUAGE SETTING AS SUGGESTED BUT DIDNT WORK...PLUS ANOTHER ISSUE.. THIS CAN BE SEEN IN THE GRAPH ATTACHED..
BEST REGARDS
RENATO
Message 11 of 24
(4,241 Views)
RENATOMUSICA,
Can you attach the following items from the comptuer experiencing this issue?
  • Screenshot of NI License Manager showing your Measurement Studio license and status (in the main window)
  • Screenshot of the Measurement Studio > Licenses screen inside Visual Studio
Have you tried selecting Measurement Studio > Refresh Project License File and then selecting Build > Rebuild Solution?
Jared A.
Message 12 of 24
(4,226 Views)
HI JARED,
THIS OPTION....
IS NOT AVAILABLE IN MEASUREMENT STUDIO MENU ON A VC++ PROJECT.. BUT INDEED APPEARS IN A C# PROJECT.
IN ONE OF THE NI SAMPLE PROJECTS C#  I TRIED AS SUGGESTED...
BUT STILL THE SAME TROUBLE.
ATTACHED DETAILS OF THE SCREENSHOTS REQUESTED.
BEST REGARDS
Message 13 of 24
(4,222 Views)
Renato,
I attempted to recreate this issue and I could not. I installed MS 2012 with VS 2010 on XP SP3 Spanish. I did not have to change my language settings. I received no licensing issues.
I believe the issue is related to a stale .licx file attached to your project. To resolve this issue, you will want to delete any *.licx files included in the project, and then remove and re-add any Measurement Studio references. This should remedy the issue and allow you to build the project.
Jared A.
Message 14 of 24
(4,200 Views)
HI JARED.. I DID ALL AS SUGGESTED .. BUT NOTHING SEEM TO FIX THE PROBLEM.. I WILL UNINSTALL EVERYTHING AND REINSTALL ALL THE SOFTWARE AGAIN.. WOULD I NEED ANOTHER CODE FOR LICENSE EVALUATION?  I´LL LET YOU KNOW ANY NEWS..
B REGARDS
RENATO
Message 15 of 24
(4,193 Views)
I already reinstall the software and the same issue..  I also installed on my laptop same unlicensed control problem.. Il try to download de ms installer again.. If i bought the full version you'd think it'd be still happening?
Message 16 of 24
(4,190 Views)
Hi Kred i reinstalled the software.. and got to the point of running the example projects on c# succesfully. I noticed that theres no examples on VC++ as well, only cs and vb. i went through all the suggestions you´ve made ... but still get the unlicensed message for new VC++ projects. The file you told me to erase shows up again every time i open the form where the control(knob for exmple) is place in the main form. if you check on this conversation...
http://forums.ni.com/t5/Measurement-Studio-for-VC/Measurement-studio-expired-first-day-I-install/m-p...
the person from NI said..
Re: Measurement studio expired first day I install
Hi Mark,
R&D took a look at this problem and I believe they have a workaround for you while they work on the official fix. Try the following steps:
1.  In the Control Panel, go to Regional and Language Options.
2.  In the Regional Options tab, under Standards and Formats, change the format to English, United States.  (Inglese (Stati Uniti) in Italian.)
If you do decide to activate your copy of Measurement Studio, this issue shouldn't be a problem anymore since it is only related to the evaluation version.
Hope this helps!
Stephanie R.
Stephanie R.
so.. if i buy the license for the standard version .. do you think this problem could be solved? would it be guaranteed??
best regards
Message 17 of 24
(4,181 Views)
Hello Renatomusica,
We do not ship examples for VC++, only for CS, VB, and ANSI C.
Did you try to follow Stephanie's steps?
I believe that buying a license will solve the problem. If the fully licensed software would somehow cause a similar issue, we would guarantee troubleshooting it until it was resolved.
Jacob R. | Applications Engineer | National Instruments
Message 18 of 24
(4,172 Views)
ok. I have an idea.. given the fact that you have spanish versions of xp and visual studio.. please build a simple vc++ project with a knob or something alike and send these fiels to me ...i if i can build it succesfully i´ll check it thorughly  to se if theres a setting that could be wrong on my project properties..
best regards
Renato.
Message 19 of 24
(4,169 Views)
Renato,
Thank you for the suggestion. Previously, I had not tried to build and run a project using one of the Measurement Studio controls (knob).
When I attempted to run the Visual C++ project, I ran into the same (or a similar) error you are experiencing:
We are currently in the process of reporting this issue to R&D. This message only occurs with the evaluation (unlicensed) version. Upon activation, this message will no longer display. Thank you for bringing this to our attention, we truly value feedback like yours.
Jared A.
Message 20 of 24
(4,151 Views)
