Measurement Studio for VC++
How to get config data about NI boards in the system?
I'm using VC++ (no .NET and no LabView) and would like to know what NI boards are currently installed in the system. I suspect one of the best ways would be to use WMI, but I don't know which providers may give me information about NI-related configuration available in the system - what kinds of boards, driver versions and may be others.
(7,048 Views)
Hi avmikh,
If you are using a DAQmx device you can call the C API for DAQmx in VC++ and then use this function: int32 __CFUNC DAQmxGetSysDevNames(char *data, uInt32 bufferSize);
Hassan Atassi
Director, ni.com
(7,021 Views)
Thank you for suggestion.
I'm using both DAQmx and a previous version of NI driver. I'd like to have a solution, which would check if a previous driver is installed, if DAQmx is installed, and which NI board, if any, is present in the system. At this point I need just some generic information, like "PCI 6229 board", for example.
(7,018 Views)
Hi avmikh,
When you say a previous version of NI Driver are you referring to Traditional DAQ?
Hassan Atassi
Director, ni.com
(7,001 Views)
I'd like to add my 2 cents here.  My system is using D/A's, Digital I/O, A/D via DAQmx, and waveform generators via niFgen.  Code is in C/C++.  The software has to control different boards depending upon the applications specific requirements.  How can I, at run time, get a list of all the National Boards connected to the PC?
Thanks and Regards
- Neil Shore
LTI, Inc.
Sr. Software Engineer
(6,785 Views)
Hi Neil,
Check out this example program: Programatically accessing list of NI-DAQmx devices in a computer using VC++
Hassan Atassi
Director, ni.com
(6,779 Views)
Hi Hassan,
Thanks for the reference.  I'll check it out and get back to you.
- Neil Shore
(6,773 Views)
