Measurement Studio for VC++
How must I read the "CopyBuffer" variable when it points to a color image?
  I'm looking some samples to acquire images from Visual C++ 6.0 and I have some questions.
  I see that the "CopyBuffer" variable (at ImaqThread function from LLGrab.dsw proyect) is pointing to the memory direction where image's pixels starts. Well, when I capture color images I see that each pixel has 4 bytes, but I don't know what is the format that it's using.
  I would like to know which byte of the pixel matches to R, which byte matches to G, which byte matches to B, and what means the 4th byte.
  I would appreciate your answer,
  Thanks!!!
(3,874 Views)
Hi Gare,
Based on the NI Vision Concepts Manual (see page 1-4), that 4th byte is the alpha plane, which is a channel used to code extra information (such as gamma correction, transparency, etc.) about a color image.  However, this value is typically not used for RGB representation.  In big-endian format (most significant bit to least), the order of the bytes for a four-byte RGB pixel is: alpha (not used), red, green blue.
Hope this helps,
Irene Chow
(3,862 Views)
  Thanks, Irene!!! Smiley Happy
(3,860 Views)
