Measurement Studio for VC++
How do I set the input channel on a counter for frequency measurement
I am using a counter on a 6250 card and want to measure a frequency on PFI3, using Dev1/ctr1.  The default input channel for counter frequency input is FPI4.  The documentation suggests that you can change the default input channel.  What is the DAQmx C command to do this?  The help files and example programs on absolutely useless for finding the answer, (as well as the paid for tech support service contract...they only support Labview/LabWindows according to the guy I spoke with).
Thanks in advance,
Eric
(6,823 Views)
Hi Eric,
I think the DAQmx C command you are refering to is DAQmxSetCIFreqTerm.  This is located under List of Channel Properties>>Counter Input>>Input Terminal.
Also, there is a document that explains how to do this in LabVIEW, CVI and C on our website.
Changing the Input Terminal (Source) for a Counter Measurement with NI-DAQmx
Jordan F
(6,808 Views)
Thanks Jordan, it worked perfectly!
(6,781 Views)
