Measurement Studio for VC++
GetPulseParameter Function
I have few questions about the following parameters in this function:
1.  Are the top & base measurements calculated from the average of the + / - width or is it based from a few samples in the +/- width?
2. The width & delay measurements are not clearly descibed.  I used these parameters and the results are incorrect.  My pulse is at
     5 mS and the width measurement was 3, sometimes 5000.  Post-processing will give me a reading of 5mS.
     Please refer to the pulse.xls & RecordRstOut_1.xls attachments.
3.  I tried using the Amplitude function in attached vector but instead of the expected Vpp of 20 V, the measured Vpp is @10V only.
    It has two distinct peaks and it looks bi-modal yet my readings are incorrect.     Refer to the last attachment.
Thank you.
A
Message 1 of 1
(6,071 Views)
