Measurement Studio for VC++
Error 229665 when run ContGen-IntClk.c (example file) pci 6229
Dear All:
I try to use pci 6229 to send analog signal by using the given example program, ContGen-IntClk.c, in DAQMX 8.3.
I use Visual c++ 6 to compile it.
After I run the exe file, monitor show error
"DAQmx Error: Internal software Error occureed in MIG software.
Status code: -229665"
(Note: the result was the same, when I did with visual basic)
How should I solve this problem?
My computer has  operating system: Microsoft XP 2002, CPU p4.
Thank you,
Thongchai Phairoh.
(7,147 Views)
Hey Thongchai,
Thanks for contacting National Instruments.  This error is usually associated with Measurement and Automation Explorer having a problem with it's database and is usually fixed with a reinstall of the driver or repair of the driver.
You could try a few things to attempt to resolve this issue.
  1. Attempt to repair the driver from the Control Panle and highlighting National Instruments and click, Change\Remove and highlight NI-DAQmx and click the repair button.
  2. Reinstall the DAQmx 8.3 driver.
  3. Upgrade to either 8.3.1 or to the newest version 8.5
Let me know if you are able to resolve this with any of these options.
Kenn North
Principal Product Manager - Search, Digital Analytics
http://ni.com/search
(7,135 Views)
Thank you Kenn for your helping
It work by using your suggestion in step 1 and 2.
Thongchai.
(7,112 Views)
