Measurement Studio for VC++
Create a continuous data stream from C++, and read it in LabView
Hi guys,
I am doing a project exactly like the one dr8086 said, except I am doing it vice versa. Meaning that I am collecting data from an orientation tracker using LabVIEW and then I want to read these data in VS C++ to run an animation (with OSG) in real time. I am using ActiveX automation technology to communicate between LabVIEW and my C++ code. My C++ code runs the VI and it starts collecting data (Variant type), but I cannot see the data stream as the result of running this code. What I get with cout is basically three (x,y,z) static numbers that are not only static and don't change with tracker moves, but also don't show a correct static number. Can anyone (especially you two my friends that were discussing a similar problem) please help me on this. If you want, I can provide the code.
Thank you very much in advance,
Reza
Message 11 of 13
(3,342 Views)
You should post the code because otherwise it's difficult to say what the problem is. I haven't worked with ActiveX, so I could only try to help, but I'm sure others could help if you post more info.
Message 12 of 13
(3,340 Views)
Thanks... The code is attached. It was a initially a code for running a Robot VI and I have changed it for my purpose. I want the code to give me a data stream that comes from LabVIEW, but it rather give me 3 static point. Alos, this is when I run the code using using VC++ 2003 and LabVIEW 8.5. When I run it in VC++ 2010 and LabVIEW 2010, I get three unhandled exceptions and 3 wrong static points.
I appreciate your help.
Message 13 of 13
(3,338 Views)
