Measurement Studio for VC++
CAN 8513 Problem
NI - CAN model 8543 driver version 14.5 1、How to realize the timing sending function,The time to ask send frame 1 ms or 2 ms 2、How to use nxPropFrm_CANTxTime? Which function can be called it? 3、How to use nxPropFrm_CANTimingType? Which function can be called it? Best with examples of C language ,thanks
(3,387 Views)
It is possible to use NI-CAN board in Measurement Studio C# (C Sharp). However, it is not officially supported by National Instruments.
To call functions from ni-can.dll you need to create wrapper functions. For example to wrap the following NI-CAN function:
nctTypeStatus NCT_FUNC nctInitStart  (
             cstr ChannelList,
             i32 Interface,
             i32 Mode,
             f64 SampleRate,
             nctTypeTaskRef *TaskRef);
you need to create the following prototype in C# (C Sharp):
[DllImport("C:\\WINDOWS\\system32\\Nican.dll")]
public static unsafe extern int nctInitStart(string ChannelList, int Interface, int Mode, double SampleRate, int* TaskRef);
You need to use keyword unsafe in the prototype to be able to call external functions from dlls. Also, you cannot use char* type, instead you use string datatype. Also, to instead nctTypeTimestamp datatype use the following structure:
public struct CanTimestamp
        public int LowPart, HighPart;
(3,324 Views)
