07-15-2005 05:28 PM
07-18-2005
01:07 PM
- last edited on
11-25-2025
02:00 PM
by
Content Cleaner
Hi Kiko,
Great to see that you are asking questions here first, you definitely came to the right place.
Since you are starting with a clean slate as far as knowing how to use this board we can start off on the right foot.
I would recommend starting in the example files. You can find some excellent examples that should do almost exactly what you are trying to do by looking in this path:
C:\Program Files\National Instruments\NI-DAQ\Examples\DAQmx ANSI C\Digital\Generate Values
Look for the example that best represents what it is you are trying to do. You will notice that all of the examples have a general flow to how they call the board.
It's really not all that difficult and should you run into any problems or errors don't forget to search ni.com or the forums to see if others have run into similar issues to what you are facing.
Regarding how the states for digital lines work. The short answer is that if you set a digital line to high it will stay high until you set it back to low and vice versa. For more details on everything digital check out our Digital Fundamentals page.
Best of luck!
07-25-2005 11:17 PM
