Measurement Studio for VB6
software trigger
i intend to start and stop my software( cpp or Basic or Delphi)  over a Digital tigger, and using NI Compact DAQ with
1 : NI - 9215
2 : NI - 9263
3 : NI - 9472
4 : NI - 9421
5 : NI - 9401
How will Software will be get informed that a trigger is activated?
The trigger signal should not start any Task but the Software will start the whole process,
 as soon as a trigger signal is detected.
Is there a "event" or "message " which will be generated or should a thread observe the Digital Input whole the time?
with Regards
Hassan Majedi
(6,544 Views)
hello hassan majedi,
you could try 2 ways to detect your trigger.
one way would be to create a digital task, which uses change detection, see the manual and see the DAQmx examples for change detection, which are usually located at:
"C:\Program Files\National Instruments\NI-DAQ\Examples\DAQmx ANSI C\Digital\Read Values\"
if you don't want to create a task, you must poll your signal within your software, as you mentioned.
regards,
robert h
NI germany
(6,531 Views)
