Measurement Studio for VB6
creating setup files using IMAQ Vision components
I had purchased IMAQ vision (version 6) with Measurement studio base package(Ver6-Professional Edition) for working in VB6 in 2002. After compiling exe file and creating setup files by using visual studio package and deployment wizerd when I installed and ran the program in a different computer i got the msg"Run-time error'30227' Newer version of IMAQ vision is required". I used the following ocx files:cwimaq.ocx,file version6.0.3.563, cwmv.ocx,file version6.00.0003, cwui.ocx, file version6.0.589. I am working in win98 platform.can you please help me.
regards
(6,522 Views)
Borty--
      On the deployment/target computer have you installed the IMAQ driver and the Vision Deployment Engine?  Both of these pieces of software need to be installed before you can use them.  In your post it mentioned Vision and so I'd bet the only thing that is needed is the Vision Deployment Engine.  Since your version of Vision is so old you'll have to call here and speak with a represenative to get the software and appropriate licenses. Also, make sure that you get the same version of deployment engine as the version of Vision that you have.  The contact number for inside sales is (888) 280-7645.  Thanks.
-John H.
http://www.ni.com/support
(6,508 Views)
