Hello
When developing web components, the necessary files should be downloaded automatically when you get to the web page ( kinda like a web page that uses flash or quicktime components). If you did not have any errors while packaging the components up, you might want to make sure that the your security settings on the web page allow you view activex controls. And also check this
link for general issues with the PDW.
Answer 2:
You need to have LabVIEW RT to run code on a 7030 board, because only LabVIEW can target it. You can write dll's using CVI that would run on the RT platform, but you would still need LabVIEW to run the code. Measurement Studio does
not have any support for RT at this point.
Answer 3:
Check out these examples
http://venus.ni.com/stage/we/niepd_web_display.DISPLAY_EPD4?p_guid=B45EACE3E14B56A4E034080020E74861&p_node=DZ52016&p_submitted=N&p_rank=&p_answer=&p_source=Internal
http://venus.ni.com/stage/we/niepd_web_display.DISPLAY_EPD4?p_guid=B45EACE3D7DD56A4E034080020E74861&p_node=DZ52139&p_submitted=N&p_rank=&p_answer=&p_source=Internal
These are examples of making an intensity plot using the 3dgraph control.
I hope this helps
Bilal Durrani
NI
Bilal Durrani
NI
