03-28-2003 06:51 PM
03-31-2003 07:01 PM
04-01-2003 07:37 PM
04-14-2003 05:46 PM
04-14-2003 08:50 PM
04-16-2003 01:04 AM
		04-21-2003
		02:52 PM
 - last edited on
		07-20-2025
		04:57 PM
 by
			Content Cleaner
Thank you for keeping me in the loop as far as your investigations. The problem is most likely because your update rate (1024 Hz) is over the specified recommended rate of 1 kHz. You can see this on page A-14 of the NI 6034E/6035E/6036E User Manual. You were probably able to improve performance since this rate is system dependant and since it's only slightly over the maximum rate. Disabling other interrupt devices provided more bandwidth to the DAQCard.
However, nonetheless you should be getting an NI-DAQ error when the AO stops. I realize this is still a problem and I have notified the
right people. So thank you for your help. As for your current situation, if nothing else I suppose the only thing you can do is just reduce the update rate below 1 kHz.
Let us know if there's anything else we can do.
--Russell
04-25-2003 08:52 PM
05-05-2003 06:30 PM
