I tried to replicate this issue; however I had no problem binding the CWNumEdit control using the Read AutoUpdate Access Mode. What I did was bind the Value property of the CWNumEdit to a DataSocket URL and set the Access Mode to Read AutoUpdate. I then wrote to that URL from another application and the CWNumEdit control in my VB6 application would update automatically. So, first I am curious what version of Measurement Studio you are using (I did this in Measurement v7.1), and do you see this problem only when you are reading from your OPC server or do you see this behavior when you read from a DataSocket URL as well?
Kevin L.
NI
