Measurement Studio for VB6
How do I plot multiple plots on a graph when each plot has a different set of x values using Measurement Studio
All information I have found to date talks about plotting multiple graphs each of which has the same set of x values. I am plotting 3 plots each of which has a different set of x values.
(4,238 Views)
You would need to use the PlotXY method on each plot object. Something like:
CWGraph1.Plots(1).PlotXvsY xData1, YData1
CWGraph1.Plots(2).PlotXvsY xData2, YData2
CWGraph1.Plots(3).PlotXvsY xData2, YData2
Best Regards,
Chris Matthews
(4,238 Views)
I have already tried this and I get an error message when it tries to execute the line of code that generates the second plot..."invalid index". Any thoughts?
(4,238 Views)
I added a plot to the collection cwgraph1.plots.add and I was able to get by the index error but the 1st plot is cleared when the second one is plotted. How can I get the 3 plots on the graph at the same time?
(4,238 Views)
I'm not sure why you are having problems. It works fine for me. Here is the project I used. I'm using Measurement Studio 6.0.
Chris
(4,238 Views)
Chris's example works fine. Is there any way we can add second X Axis? just like we do that for Y Axis. The reason to use that is I want to display two sets of data (They have different X values for two channels.) with their individual X scale in the entire plot area. Is it possible,chris? Thanks
(4,238 Views)
No, currently only multiple Y Axis are supported. I'll relay your request to our developers. You could probably mimic a second axis with a slide control.
Best Regards,
Chris Matthews
(4,238 Views)
