Measurement Studio for VB6
How do I export the image from CWGraph3D to a Powerpoint presnentation ?
The 3D plot from Measurement Studio is neat. I wish to use the image generated in CWGraph3D for presentations. I can print it through a printer. But,I don't know how to export the image to, say, Powerpoint, or to a file (JPG or GID).
(3,678 Views)
The CWGraph3D's ControlImage method returns an IPictureDisp for an enhanced metafile. You can pass the return value of ControlImage to VB's SavePicture method to save the metafile to a file. For example, if you wanted to create a metafile at C:\surface.emf, you could do it like this:
SavePicture CWGraph3D1.ControlImage, "C:\surface.emf"
If you want to save to a JPEG, GIF, or some other image format, that is a lot more work. If you're using VB6, that would require using a third party library to perform the conversion. If you're using VB.NET, this would be pretty straight forward with the System.Drawing classes. Reply to this post if you're using VB.NET and I'll look into coming up with an example.
- Elton
(3,678 Views)
