I see a problem sometimes in a program I have written that has CWNumEdit buttons. These buttons change times stored in a database.
The problem is that some of the CWNumEdit buttons increment in value when you click the UP arrow, while others decrement?!? On the other hand, some of them when you click the down arrow, they increment, while others decrement!>!
This doesn't make sense to me at all. It only makes sense that when you click the up arrow, the values will increment. I checked the settings for all the buttons, and they are all the same, however, as I described, they do not respond in the same way.
Any help is appreciated!
CM
