 dlittle
			dlittle
			10-09-2006 05:11 PM
10-10-2006 11:15 AM
There is documentation that states which video cards work with these graphs because realistically, they should all work, but they are of course limited by the card with what type of frame rate you will see as your points you plot grow larger. I noticed you said you are plotting around 300 X 300 data points, but does this same behavior occur in our example programs that plot less data points than this? If the example programs work fine, it would not be a compatibility problem but instead would be a limit of the video cards themselves. The only way to fix this on the non-working video cards would be to limit the amount of points you are plotting or, as you stated, turn off hardware acceleration.
