wsdl
I'm able to access a web server which was created for an application through LV 8.2, however I'm not able to create an assembly as I don't have the wsdl link.
Is there any way to access this link??
RK
(4,093 Views)
Hi RK,
The LabVIEW web server does not use WSDL for its description.  You may import a WSDL web service into LabVIEW, however, right now, there is not a way to export a web server created with LabVIEW to allow the creation of a .NET assembly.
If you would like to make a suggestion for future releases of LabVIEW, please visit the Product Suggestion Center.
Donovan
(4,068 Views)
Hey Reiry,
As Eric V had mentioned, do you know where these errors are occurring? Are these errors you are receiving when you are working in the LabVIEW environment? Could you point out or give a link to which example you are working with so we can take a closer look at what you are doing that generated these errors? It is not extremely clear what your issue is.
Let us know if you have any more information that could make your issue a little clearer.
Ben
Applications Engineering
Hope this helps.
-Ben
WaterlooLabs
(3,712 Views)
