using flex_get_motion_board_info with .net 2005
Hi
I'm using VB.net 2005 with Ni-Motion.
FlexMotion32.dll version 7.3.1.49152
and the Max version is 4.3.0f0
the Board is a PCI-7350 6 axis
I'm trying to get the number of axis available using the
function call Status = flex_get_motion_board_info(BoardID, NIMC_NUM_AXES, informationValue)
this is the code I'm using
Public Sub New()
Dim Status As Long = 0
Dim BoardID As Integer = 1
Const NIMC_NUM_AXES As Long = 1510
Dim informationValue As Long = 0
End Sub
The problem is, Status always returns a non-zero value (8589864559) to be exact.
I do not think it’s an error code because it’s not negative.
The informationValue always returns 0 also.
I've tried replacing the function call with
Status = flex_get_motion_board_info(1, 1510, informationValue)
with the same results.
The NI-Motion Function Help says that the function is compatible with the board I'm using.
I'm also using Status = flex_clear_pu_status(mBoardID)function and it works fine.
I can verify it with Max.
So I don’t think it’s a declaration issue?
If someone could point me in the right direction I would appreciate it
Thank you
Rich
Message 1 of 1
(3,094 Views)
