single data two y-axis
What I want to do is plot time vs temperature with two y-axis. The first axis (on the left) is deg-C and the second axis (on the right) is deg-F. If I rescale one axis, I want the other to rescale accordingly. I tried plotting time vs deg-C, then computing time vs deg-F and plotting that too (see attached sub-VI). But then it looks like I have two plots! Is there some way to connect the two axis together so that, if one changes, then so does the other?
(3,682 Views)
Hello, it appears that you are trying to do this in LabVIEW and not .NET.  I think you would get a much better response if you posted this on the LabVIEW forums instead.
(3,653 Views)
Yes. thank you. I actually had no intention of posting here. I still can't figure out how I did. But I couln't find a way to unpost once I saw what had happened.
(3,638 Views)
