11-13-2012 11:10 AM
I have a property editor with the following configuration:
object: scatterplot
property name: PointSize
The problem is that its representation depends on regional settings, for example:
Spanish is: "5; 5"
United States is : "5, 5"
So how to make it culture invariant in order to represent always in the same manner?
Solved! Go to Solution.
11-13-2012 02:19 PM
Hi there,
Write this peice of code at the beginning of your code.
Thread.CurrentThread.CurrentCulture = new CultureInfo("", false);
This will make the locale to be set to invariant. But this causes culture to be invariant across the thread.
Hope this helps.
Vijet Patankar
11-13-2012 02:28 PM
object: scatterplot
Spanish is: "5; 5"
EDIT
- How to get which character separator is used by the property editor?
- Can I force property editor source to use a custom separator?
The need to get the character separator is because I control what user is typing, so I only permits to user to use digits and the character separator so I need to check this character separator to allow user to type it.
11-13-2012 02:38 PM
Ok, but this will apply culture invariant to all application. Is there any way to know which character separator is using propertyeditorsource?
11-13-2012 02:50 PM
