problems deploying NationalInstruments.Analysis.Professional.dll in Web service (Exception from HRESULT: 0x80131417)
I am in the process of turning our desktop application into a web service.
The web hosting is done on a shared IIS server using ASP 3.5 and we do not have control to set the trust level of the server.
Our service application uses NationalInstruments.Analysis.Professional and when I try to send a request to the server I get the following response from the server:
Required permissions cannot be acquired.
Description: An unhandled exception occurred during the execution of the current web request. Please review the stack trace for more information about the error and where it originated in the code.
Exception Details: System.Security.Policy.PolicyException: Required permissions cannot be acquired.
Source Error:
An unhandled exception was generated during the execution of the current web request. Information regarding the origin and location of the exception can be identified using the exception stack trace below.
Stack Trace:
[PolicyException: Required permissions cannot be acquired.]
   System.Security.SecurityManager.ResolvePolicy(Evidence evidence, PermissionSet reqdPset, PermissionSet optPset, PermissionSet denyPset, PermissionSet& denied, Boolean checkExecutionPermission) +7613763
   System.Security.SecurityManager.ResolvePolicy(Evidence evidence, PermissionSet reqdPset, PermissionSet optPset, PermissionSet denyPset, PermissionSet& denied, Int32& securitySpecialFlags, Boolean checkExecutionPermission) +57
[FileLoadException: Could not load file or assembly 'NationalInstruments.Analysis.Professional, Version=9.1.35.204, Culture=neutral, PublicKeyToken=18cbae0f9955702a' or one of its dependencies. Failed to grant minimum permission requests. (Exception from HRESULT: 0x80131417)]
   System.Reflection.Assembly._nLoad(AssemblyName fileName, String codeBase, Evidence assemblySecurity, Assembly locationHint, StackCrawlMark& stackMark, Boolean throwOnFileNotFound, Boolean forIntrospection) +0
   System.Reflection.Assembly.nLoad(AssemblyName fileName, String codeBase, Evidence assemblySecurity, Assembly locationHint, StackCrawlMark& stackMark, Boolean throwOnFileNotFound, Boolean forIntrospection) +43
   System.Reflection.Assembly.InternalLoad(AssemblyName assemblyRef, Evidence assemblySecurity, StackCrawlMark& stackMark, Boolean forIntrospection) +127
   System.Reflection.Assembly.InternalLoad(String assemblyString, Evidence assemblySecurity, StackCrawlMark& stackMark, Boolean forIntrospection) +142
   System.Reflection.Assembly.Load(String assemblyString) +28
   System.Web.Configuration.CompilationSection.LoadAssemblyHelper(String assemblyName, Boolean starDirective) +46
[ConfigurationErrorsException: Could not load file or assembly 'NationalInstruments.Analysis.Professional, Version=9.1.35.204, Culture=neutral, PublicKeyToken=18cbae0f9955702a' or one of its dependencies. Failed to grant minimum permission requests. (Exception from HRESULT: 0x80131417)]
   System.Web.Configuration.CompilationSection.LoadAssemblyHelper(String assemblyName, Boolean starDirective) +613
   System.Web.Configuration.CompilationSection.LoadAllAssembliesFromAppDomainBinDirectory() +203
   System.Web.Configuration.CompilationSection.LoadAssembly(AssemblyInfo ai) +105
   System.Web.Compilation.BuildManager.GetReferencedAssemblies(CompilationSection compConfig) +178
   System.Web.Compilation.WebDirectoryBatchCompiler..ctor(VirtualDirectory vdir) +163
   System.Web.Compilation.BuildManager.BatchCompileWebDirectoryInternal(VirtualDirectory vdir, Boolean ignoreErrors) +53
   System.Web.Compilation.BuildManager.BatchCompileWebDirectory(VirtualDirectory vdir, VirtualPath virtualDir, Boolean ignoreErrors) +175
   System.Web.Compilation.BuildManager.CompileWebFile(VirtualPath virtualPath) +86
   System.Web.Compilation.BuildManager.GetVPathBuildResultInternal(VirtualPath virtualPath, Boolean noBuild, Boolean allowCrossApp, Boolean allowBuildInPrecompile) +261
   System.Web.Compilation.BuildManager.GetVPathBuildResultWithNoAssert(HttpContext context, VirtualPath virtualPath, Boolean noBuild, Boolean allowCrossApp, Boolean allowBuildInPrecompile) +101
   System.Web.Compilation.BuildManager.GetVPathBuildResultWithAssert(HttpContext context, VirtualPath virtualPath, Boolean noBuild, Boolean allowCrossApp, Boolean allowBuildInPrecompile) +51
   System.Web.Compilation.BuildManager.GetVPathBuildResult(HttpContext context, VirtualPath virtualPath, Boolean noBuild, Boolean allowCrossApp, Boolean allowBuildInPrecompile) +8773398
   System.Web.Compilation.BuildManager.GetVPathBuildResult(HttpContext context, VirtualPath virtualPath) +10
   System.Web.UI.WebServiceParser.GetCompiledType(String inputFile, HttpContext context) +43
   System.Web.Services.Protocols.WebServiceHandlerFactory.GetHandler(HttpContext context, String verb, String url, String filePath) +180
   System.Web.Script.Services.ScriptHandlerFactory.GetHandler(HttpContext context, String requestType, String url, String pathTranslated) +47
   System.Web.MaterializeHandlerExecutionStep.System.Web.HttpApplication.IExecutionStep.Execute() +307
   System.Web.HttpApplication.ExecuteStep(IExecutionStep step, Boolean& completedSynchronously) +155
Message 1 of 1
(5,451 Views)
