peak detector example Needed
Where can I find a peak detector example to determine the frequency of a signal. How do you declare 'out double' overload parameters for the peak detector? Thanks
(4,280 Views)
You can use the AmplitudePhaseSpectrum() method to first generate the frequency information of your time domain signal. Then use the PeakDetector method to find the frequency peaks. To see an example of how to use the PeakDetector, refer to the Measurement Studio shipping example found in MeasurementStudio folder under ..\Examples\Analysis\PeakDetector
Bilal Durrani
NI
(4,274 Views)
what class contains the method AmplitudePhaseSpectrum()?
(4,257 Views)
E-man,
The AmplitudePhaseSpectrum method is a part of the NationalInstruments.Analysis.SpectralMeasurements.Measurements class. Let us know if you have further questions.
Adam B.
(4,248 Views)
how do I use the AplitudePhaseSpectrum() with a signal I am reading in to measure the frequency. I don't know how to get all the parameters needed to make the method valid. Thanks
(4,239 Views)
ignore, i figured it out
(4,234 Views)
