output Digitalwaveform
Running in Windows 7 64bit
Compiling in Visual Studio 2008 Professional Edition
using the NI PXIe-6363 card
I can create the Digital waveform no problem.  My problem arises when I try to use BeginWriteWaveform to put the writing of the waveform in the background.
All of this in the attached zip, but I'll reproduce it here, I'm setting up 2 channels to output some digital pulses.
Here's how I set up the task:
        private const string TRIGGER_CHANNEL = "PXI1Slot2/port0/line0";
        private const string TTL_A_CHANNEL = "PXI1Slot2/port0/line1";
        private const string TTL_B_CHANNEL = "PXI1Slot2/port0/line2";
           signalTask = new Task();
signalTask.DOChannels.CreateChannel( TRIGGER_CHANNEL, "Signal", ChannelLineGrouping.OneChannelForEachLine); signalTask.DOChannels.CreateChannel( TTL_A_CHANNEL, "TTL_A", ChannelLineGrouping.OneChannelForEachLine);
signalTask.Timing.ConfigureSampleClock( "", signalClock, SampleClockActiveEdge.Rising, SampleQuantityMode.FiniteSamples); signalTask.Control(TaskAction.Verify); signalTask.Stream.WriteRegenerationMode = WriteRegenerationMode.DoNotAllowRegeneration; signalWriter = new DigitalMultiChannelWriter(signalTask.Stream); signalWriter.SynchronizeCallbacks = true; signalCallback = new AsyncCallback(SignalCallback);
and here is how I output the waveform:
        private void btn_Start_Click(object sender, EventArgs e)
            Int32 signals = signalTask.DOChannels.Count;
            DigitalWaveform[] wave = new DigitalWaveform[signals];
            int pulse = (int)numE_pulse.Value;
            int samples = pulse * 4;
            for (int i = 0; i < signals; ++i)
                wave[i] = new DigitalWaveform(samples, 1, DigitalState.ForceDown);
                for (int j = 0; j < pulse; ++j)
                    wave[i].Signals[0].States[j + i*2] = DigitalState.ForceUp;
                    wave[i].Signals[0].States[(j + 2*pulse) + i * 2] = DigitalState.ForceUp;
                signalClock,
                SampleQuantityMode.FiniteSamples,
                samples);
            btn_Start.Enabled = false;
            signalWriter.BeginWriteWaveform(
                true,
                wave,
                signalCallback,
                null);
            signalWriter.WriteWaveform(true, wave);
            signalTask.WaitUntilDone();
            signalTask.Stop();
            btn_Start.Enabled = true;
If I comment out the section where I BeginWriteWaveform(), and uncomment out the section where I WriteWaveform(), WaitUntilDone(), and Stop(), I get the proper digital signal out.  So I know I'm creating the wafeform correctly.
If I do the reverse, and try to use the BeginWriteWaveform(), I don't get the proper digital signal out.  Usually one of the lines goes high, and never returns to zero.
Is there anything I'm missing?
(4,673 Views)
Hello dknovick,
Have you been able to successfully run the shipping examples?  Do you see any strange behavior when running those?
Michael B.
(4,659 Views)
Thanks for the reply.
Can you point me to an example that might be similar?  These are the samples that were installed:
ContWriteDigChan_Burst - uses burst mode
ContWriteDigChan_PipeSampClk - interfaces to the NI 6536/7
ContWriteDigChan_PipeSampClokwHshk -  interfaces to the NI 6536/7
ContWriteDigPort_ExtClk - uses .WriteMultiSamplePort()
WriteDigChan - uses .WriteSingleSampleMultiLine()
WriteDigChan_ExtClk - uses .WriteWaveform()
WriteDigChan_WatchdogTimer - doesn't use a DigitalWaveform
WriteDigPort - uses .WriteSingleSamplePort()
-Dave
(4,654 Views)
Hi Dave,
Do you know if your BeginWriteWaveform is finishing and calling SignalCallback?  I took a look at your code, and you seem to be calling everything properly, and if WriteWaveform works, then the async call should work also.
Matt
(4,641 Views)
@Matt.M wrote:
Hi Dave,
Matt
Thanks for double checking things.  I was pretty sure it was being called, since I disble the button before BeginWriteWaveform and enable it inside SignalCallback (one of my own tests to see if it was being called).  Just to be sure, I added a  1sec sleep inside SignalCallback before I enable the button.  And sure enough, with the code section around BeginWriteWaveform running, the button is disable, and then 1 sec later, it's enable again.
I was able to get this to work by creating my own asynchronous task.  I created a sendDigitalWaveform() function and a delegate function as well.  Then inside btn_Start_Click(), I create a new delegate, and then BeginInvoke().
Inside the function, I'm still doing:
WriteWaveform()
WaitUntilDone()
Stop()
Not very elegant.
-Dave
(4,632 Views)
