meter range fill dimensions problem
Hi
I have one problem with meter, when I use range fill, then this range fill is visible only 90%, how I can resolve  it , see photo below
Bob
(4,983 Views)
Hello Bob!
Could you attach your code, so I can take a look at it?
Daniel.
(4,928 Views)
this is without code, I placed only this meter on the form in vb.net , now I have placed only graphic elements on the form
(4,925 Views)
There are basically two ways how you can resize an element:
- drag the sides
- modify it with code
This forum describes it precisely:
http://stackoverflow.com/questions/21317843/how-to-resize-a-windows-forms-application-in-designer-mo...
Does this solve your problem?
Daniel.
(4,919 Views)
this not resolved my problem, because I don't need resize meter, but only green fill
meter I see always 100% , but fill only 90%, no matter whether I'm doing it manually or programmatically
(4,915 Views)
