memory leak??
My application(mesurement studio 7.0 vb.net2003) get data over several datasockets(opc) from fieldpoint  every seconds.
whenever i get the data, Using memory increased several KBs.
After running the applicaton for a day, it goes up 80Mega bytes...
any solutions??
thanks for reply in advance..
(3,658 Views)
are you adding the datasocket data to an array or dataqueue ?
Philip Newman
General Dynamics
Electric Boat
(3,643 Views)
yes i did..
i made my class that creates several datasoket instances in code
and  assigned datasocket data  to a array..
Private cData() As Int16
Private nData() As Int16
Private Const channelPerIO = 16
Public DigitalIOCount As Integer
Private DataSocket() As NationalInstruments.Net.DataSocket
  Public Function GetData() As String
        Dim i, j As Integer
        Dim temp As Int16
        Dim ret As String
        For i = 0 To DigitalIOCount - 1
            Try
                DataSocket(i).Update()
                nData(i) = CType(DataSocket(i).Data.Value.ToString, Int16)
                temp = (cData(i) Xor nData(i))
                For j = 0 To channelPerIO - 1
                    If (temp And (2 ^ j)) Then
                        lvCount.Items(i * channelPerIO + j).SubItems(1).Text = IIf((nData(i) And (2 ^ j)), "True", "False")
                        lvCount.Items(i * channelPerIO + j).StateImageIndex = IIf((nData(i) And (2 ^ j)), 1, 0)
                        lvCount.Items(i * channelPerIO + j).SubItems(2).Text = CType(lvCount.Items(i * channelPerIO + j).SubItems(2).Text, Integer) + 1
                      End If
                Next
                cData(i) = nData(i)
            Catch ex As Exception
                ret += "channel" + i.ToString
            End Try
        Next
End Function
(3,639 Views)
Thanks for your reply..
That was Thread problem...
(3,634 Views)
