measure pulse frequency with 4.7 volt peak amplitude
used two shipped Measurment Studio Vb.Net 2005 Examples:
1-Example 1 : CountDigEvents  "MEASURES PULSE COUNTS" and Example 2: MeasDigFrequency_LowFreq1Ctr  "MEASURES PULSE FREQUENCY"
2-Example 1 works fine measuring pulse counts , however Example 2 did not recognize pulse frequency  , the pulse amplitude voltage is 4.7 volt peak
3-during testing used counter ch0 channle by connecting Sorce0 and Dgnd pins to signal source.
4-using Nidaqmx 9 and MIO-16xe-10 daq
5-pulse frequency around 10 khz
QUESTION:
-please advice what to do to make frequency measures ?
(5,298 Views)
Hi MyKat,
Note that the connections are different for edge counting and low frequency frequency measurements with one counter.  For the latter, you'll need to connect the signal to PFI 9 rather than PFI8 as you did for edge counting.
http://zone.ni.com/reference/en-XX/help/370466W-01/mxdevconsid/eseriessigcounters/
-Jim B
Applications Engineer, National Instruments
CLD, CTD
(5,263 Views)
James,
Thanks .. works fine ..
(5,099 Views)
