how to use waveformgraph class
Hi, Hope some can help?
I am trying to use the waveformgraph class. To try and understand this l created a project with a waveformgraph and have a button to display 10 readings and a button to clear the graph.
I want to set the mode and range for both the X and Y axis using code. See attached project.
Regards
Ian Calder
(3,171 Views)
Hi Ian,
Could you please clarify whether you mean mathematical mode and range of the plotted values, or is it the update mode for the chart and the scale range of the chart.
Kind regards,
Stephen C
(3,141 Views)
