graph performances
Is there an official documentation about the MS graph performances ? I need to know the number of points I can display in a graph (of course it depends on the hardware) because I feel MS does not target applications with an hudge amount of points.
Pipo
(3,459 Views)
Hi Pipo
I don't know what "hudge amount" means for you, but I can put more than 300,000 points on a waveformGraph. I tought that what a hudge amount because I am more limited by the software that can read 300,000 ascii lines (wordpad), than the graph...
(3,454 Views)
Thank you for your answer.
I think that 300k is an nice amount of points 🙂 ... however a graph with a 300k HistoryCount will instant die if your try to call PlotYAppend.
Even with a lower amount of points, let's say 30k (10 graphs with 3k points each), the ploting job will be very time consuming.
(3,450 Views)
