custom ticks marks
I am using the ActiveX control graph and I need to put third octave values on evenly spaced ticks on the X axis.  Is there a way to do this?
Each value for a tick mark would follow the formula: val = 10^n/10.
VS2005, MS 8.1, C#
Scott
(3,246 Views)
Hi Scott,
If you are using C#, the best way is to use the .NET Controls (WaveformGraph, ScatterGraph, etc. in the Measurement Studio section of the toolbox).  Edit the XAxes, and choose LogBase 10 with a Logarithmic ScaleType.  If you don't like the MinorDivisions, you can set their TickVisible property to False.
Cheers,
David Goldberg
Software R&D
(3,227 Views)
