create null reference
I wish to create a null reference as part of an error handler.
Is there such a thing as a "Null Reference" that I can create?
(3,825 Views)
I am sorry but your question seems to be too general.
A possible problem:
- you have to communicate with a 3rd party library written in C/C++;
- there is a function with one of its parameters declared as a pointer;
- you have to set a null reference for this parameter.
If this is your case,  just declare this parameter as an integer and set it to 0.
1) C++ prototype:
void Foo (char *str);
2) VB.NET:
Public Declare Sub Foo Lib "FooLib" (ByVal str As String)
Public Declare
Sub Foo2 Lib "FooLib" Alias "Foo" ( _
            ByVal str As Integer)
Foo("Fooo")     ' sends reference to this string
Foo2(0)         ' sends null reference
(3,808 Views)
I realize now that it is too general.
However, that stems from NI's usage of the term "reference".
I want a null reference to an ODBC VI.
I can create a constant by right-clicking on the input to the VI, but I do not understand what that does.
That may be all I need.
(3,809 Views)
This forum is titled as "Measurement Studio for.NET Languages". And you are a LabVIEW developer, aren't you? I believe you will find an answer on the forum "LabVIEW".
(3,799 Views)
My bad, must have hit the wrong button.
Sorry.
(3,794 Views)
