copy digital signal
Hi
I'm using NI-DAQ and just want to copy a TTL signal (about 30 hz).
I know how to measure the frequency and set an output pulse train. I want a copy of the signal, so that I can delay it.
kind regards
(3,582 Views)
hi,
i want to do the following but i get an exception (see attachment). What am I doing wrong?
private
void startButton_Click(object sender, System.EventArgs e)
measureTask = new Task();
CIChannel channelIn = measureTask.CIChannels.CreateCountEdgesChannel(counterComboBox.Text, "Count Edges", edgeType, Convert.ToInt64(initialCountTextBox.Text), countDirection);
measureTask.CounterOutput +=
new CounterOutputEventHandler(OutputMethod);
myCounterReader =
new CounterReader(measureTask.Stream);
measureTask.Start();
private void OutputMethod(object a, CounterOutputEventArgs e)
//do something
(3,572 Views)
Hello Ghannes,
I'm not entirely sure what you are trying to achieve.
In your first post, you wrote that you wanted to read a TTL signal and write it back with a delay.
The code in your second post suggests you want to trigger an event for every edge of your signal.
Or are these two post unrelated?
Thank you,
Johannes
(3,548 Views)
