connect host pc running winXP to Stand-Alone cDAQ 9139 running win7 embedded via Daqmx
Hi
trying to connect Stand-Alone cDAQ  9139 running embedded win7 to host PC running winXP via Daqmx 9.6 , both 9139 and host pc has Daqmx9.6 installed and connected with direct ethernet cable .. i need to review any steps available to do this task , the only one i found yet is for Stand-Alone cDAQ  9139 running Real Time mode not Win7 mode.
Best Regards
MyKat
(6,105 Views)
Hi MyKat-
We do not currently support remote connections between Windows host PCs and WES7 cDAQ-913x controllers.  As you noticed, this type of remote connection is possible with a LabVIEW RT-based cDAQ-913x controller.
Hopefully this helps-
Tom W
(6,100 Views)
Hi Tom
please advice if NI might implement network with host pc feature for win7 embedded?
thanks
(6,057 Views)
Hi MyKat-
We have considered adding this support, but right now we do not have that feature committed for a future release.  I am interested to know why using this feature with a remote WES7 target is necessary (compared to remotely targeting a LabVIEW RT-based system) so that we can consider that feedback.
Thanks again for your interest-
Tom W
(6,029 Views)
Hey MyKat-
I just noticed that this post is in the 'Measurement Studio for .NET Languages' forum, so I wanted to make sure my message was not misleading.  If we added a feature for remotely targeting WES7 cDAQ controllers, it would be a LabVIEW-based solution.  I do not expect either RT or WES7 systems to be remotely targetable from Measurement Studio/Visual Studio environments.  Apologies for any confusion.
Tom W
(6,028 Views)
