camera input in c#
In the Boardsearch, I found interesting things, but I don't found anything for c#. Can you give me some examples, or samples? I hope you can help me!
mfg
(5,023 Views)
Twist0r,
there are several examples for IMAQ image acquistion for VB.NET and VC++ .NET. if have found even one example which might suite you for C#.
I attached the example to this post becauese i am not sure where it is located on the web (if at all). please note that this example is not supported by NI otherwise it would be available directly via www.ni.com.
Norbert B.
Norbert
Expert: Geometry
(5,001 Views)
