c# graph disable change axis range
when I double click the axis max or min  ,i can change it's value; how can I disable this .
(2,827 Views)
This can be configured through the appropriate "interaction mode" property. In WPF, you can use the InteractionMode property on Axis<TData>; in Windows Forms, you can use the InteractionMode property on the Graph class.
~ Paul H
(2,739 Views)
