Writing C# Synchronized Read/Write Functions
Hey Caleb,
It looks like we have Measurement Studio 7.0 here.  I tried finding the GpibSession stuff, but I'm not sure if thats in this version.  Do you know if it is?
Nick
Message 11 of 32
(3,991 Views)
Hi Nick,
Measurement Studio 7.1 only has support for Visual Studio 2003.  You aren't seeing all of the capabilities of Measurement Studio because it doesn't integrate properly with Visual Studio 2005.
Caleb W
Message 12 of 32
(3,989 Views)
Hey Caleb,
Ok, I think the problem I'm having now is doing too many Device.Write()/Device.Read()'s on top of each other.  I have a loop that does a Write, then a Read, and what happens is it does the first Write/Read fine, but when it goes to do the second iteration thourgh, it times out.  I put a delay of like 5 milliseconds at the end of the loop and it works most of the time (still times out after some amount of time).  Is there a way to check if its ok to read/write to the device?
Nick
Message 13 of 32
(3,950 Views)
Hi Nick,
It depends on how your device responds to commands.  Some devices set the RQS bit and others set the SRQ line.  If you use the functions in Measurement Studio you can check those bits.  If those functions aren't available, you might need to put a longer wait.
Caleb W
Message 14 of 32
(3,946 Views)
Hey Caleb,
Do you know if the Device.Wait(GpibStatusFlags.IOComplete | GpibStatusFlags.Timeout) works?  It seems like I have to reset the flags or something (what I see is it looks like it just continues regardless of the flags), but I dont see any command to do that.  Would this work for what I need?  Should I maybe wait on a different GpibStatusFlags?  Should I be waiting on the Board object or the individual Device object?
Nick
Message Edited by Schoon on 10-20-2008 05:22 PM
Message 15 of 32
(3,944 Views)
Hi Nick,
The IOComplete Status flag will be set once the communication is successful, not when the device is finished and ready for the next command.  Are you able to use the function: public bool CheckForSrq().  This will return true if the SRQ line is asserted and false if the line is not asserted.  You could use this if your device sets the SRQ line.
Caleb W
Message 16 of 32
(3,940 Views)
Hey Caleb,
Yeah, I think the solution you mentioned about making sure the command is complete works.  But now I seem to be running into a problem with the actual Device.Write and Device.ReadString calls running back to back.  I tried adding the IOComplete status flag wait, but still had problems (mainly timing out).  When I intruduced a sleep in between the Write/Read calls, it worked.  So I'm not sure if I have to clear those status flags before doing a Wait on them or what (because it seems to just go right through them).
Nick
Message 17 of 32
(3,922 Views)
Hi Nick,
Once the actual write completes for Device.Write it will set the IOComplete Flag so you will go directly into the Device.Read even if the device is not yet ready to be read.  That is why you go straight through the Wait.  If your device supports setting the SRQ line, you can check that, but beyond that you will need to rely on a time delay.
Caleb W
Message 18 of 32
(3,918 Views)
My current setup is that I have a USB GPIB Board and 4 Lambda power supplies.  I create the Board object and then create 4 seperate device objects for each power supply.
This is the setup:
mGpibBoard = new Board(mGPIBConfiguration.GPIBBoardID);
mGpibBoard.AbortAsynchronousIO();
mGpibBoard.TerminateReadOnEndOfString = false;
mGpibBoard.SendInterfaceClear();
mGpibBoard.BecomeActiveController(true);
mGpibBoard.SetEndOnEndOfString = false;
mGpibBoard.SetEndOnWrite = true;
mGpibBoard.BusTiming = BusTimingType.HighSpeed;
mGpibBoard.UseAutomaticSerialPolling = true;
Example device setup:
Unit = new Device(mGPIBConfiguration.GPIBBoardID, gpibUnit.PrimaryAddress);
Unit.TerminateReadOnEndOfString = false;
Unit.IOTimeout = GPIB_DEVICE_TIMEOUT_VALUE;
Unit.SetEndOnEndOfString = false;
Unit.SetEndOnWrite = true;
Unit.ReaddressingEnabled = true;
 try
gpibUnit.Unit.Write("*ESE 0;*SRE 16"); // Only care about MAV
Once I have all 4 devices setup, I loop through them to check the voltages,currents, state, etc
I want to syncronize them so my program does not advance until I have the information from these calls.
I've setup the the following sync read/write functions as per our discussions:
 public void SyncWrite(String command) // this seems to be ok for what I need
   if (Unit != null)
      Unit.Write(command +
";*OPC?");
      Unit.Wait(GpibStatusFlags.DeviceServiceRequest | GpibStatusFlags.Timeout);
      String restult = Unit.ReadString(128);
      Unit.Wait(GpibStatusFlags.End | GpibStatusFlags.Timeout); // Wait for MAV or timeout
 public String SyncRead(String command)
   if (Unit != null)
      // Setup for a mav event or message avialable
      Unit.Write(command);
      Unit.Wait(GpibStatusFlags.DeviceServiceRequest | GpibStatusFlags.Timeout); // Wait for MAV (command query puts data in queue that triggers MAV)
       GpibStatusFlags status = Unit.GetCurrentStatus();
      status &= GpibStatusFlags.Timeout;
      if (status != GpibStatusFlags.Timeout)
      {         read_string = Unit.ReadString(128);  <-- Problem is here
          Unit.Wait(GpibStatusFlags.End | GpibStatusFlags.Timeout); // Wait for End of String found
   return read_string;
The problem I'm running into is that at random times for random devices, the line above that says "Problem is here" times out.  It's complete random.  I looked at the IOTimeout values and they are set 10 seconds for the Board and I set the devices to 1 second (cant wait too long).  Do you have any idea why it would time out there randomly.  It seems like the MAV is triggering the event, but when it goes to read that data out, there isnt any in the queue.  I do get the correct current and voltage readings for each power supply that I expect.  It must be something I'm setting up wrong.  Do you know off hand how long Device ReadString calls typically take?
Nick
Message 19 of 32
(3,893 Views)
Hey Caleb,
I also set the IOTimeout for each device to 10 seconds and it still times out.  Do the Board and Device IOTimeout values need to be the same?  Could a ReadString call really take more than 10 second per device?  Should I be configuring the GPIB cables in any special way (right now they are just connected randomly, not in any star or other configuration)?  Let me know if you think of anything or see any problems in my code.
Nick
Message Edited by Schoon on 10-23-2008 10:19 AM
Message 20 of 32
(3,891 Views)
