Which chart/configuration should I use to be able to plot 60,000 points and see them all at one time or zoomed?
I want to be able to look at datafiles that can be up to 300,000 lines, but 100,000 is normal, similar to the way DIAdem allows.  I want to be able to see entire curves or zoom in, but when I try this the chart will only give me 1000 or so points.  Which chart and configuration would be best to accomplish this?  The x-axis is just a count 0...n-1.  Users would select a series (or multiple) and it (they) would be plotted on the chart...
Thanks.
Programming Data Acquisition and Control in Measurement Studio and Labwindows/CVI
(3,460 Views)
Hello You can click the little arrow at the top of the Chart to change other properties like History Capacity. Please be aware that you may run out of memory trying to keep a large amount of data in memory.
23156i1EC0A2BA5199FFC7
(3,446 Views)
Thanks!
(3,444 Views)
