Where is the DAQmx function reference?
I installed all the documentation (I think). Is there not a way to get a giant list of all the functions that I can search through?
(3,434 Views)
Hi pelesl,
You can find the help documentation under Start >> All Programs >> National Instruments >> NI-DAQ >> Text-Based Code Support.  If you have installed the help documentation for DAQmx with .NET, then the help files should be located in this directory.  If you search for "NationalInstruments.DAQmx Namespace" within the help file, then you will be returned a list of all the classes, delegates, and enumerations included within that namespace.
Hope this helps!
Stephanie R.
Stephanie R.
(3,429 Views)
