WaveformGraph err
有時程式在跑時會出現以下錯誤,請問會是什麼原因呢
ystem.InvalidOperationException 未處理
  Message="集合已修改; 列舉作業可能尚未執行。"
  Source="mscorlib"
  StackTrace:
       於 System.Collections.Hashtable.HashtableEnumerator.MoveNext()
       於 NationalInstruments.UI.Internal.InnerAxisElement.a(ComponentDrawArgsInternal A_0, RectangleF[] A_1)
       於 NationalInstruments.UI.Internal.InnerAxisElement.DrawForeground(ComponentDrawArgsInternal args)
       於 NationalInstruments.Restricted.ControlElement.a(ComponentDrawArgsInternal A_0, Rectangle A_1, Boolean A_2)
       於 NationalInstruments.Restricted.ControlElement.DrawChildren(ComponentDrawArgsInternal args, Rectangle clipRectangle)
       於 NationalInstruments.Restricted.ControlElement.a(ComponentDrawArgsInternal A_0, Rectangle A_1)
       於 NationalInstruments.Restricted.ControlElement.Paint(PaintEventArgs e)
       於 NationalInstruments.UI.WindowsForms.ControlBase.OnPaint(PaintEventArgs e)
       於 System.Windows.Forms.Control.PaintWithErrorHandling(PaintEventArgs e, Int16 layer, Boolean disposeEventArgs)
       於 System.Windows.Forms.Control.WmPaint(Message& m)
       於 System.Windows.Forms.Control.WndProc(Message& m)
       於 System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
       於 System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
       於 System.Windows.Forms.NativeWindow.DebuggableCallback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
       於 System.Windows.Forms.UnsafeNativeMethods.DispatchMessageW(MSG& msg)
       於 System.Windows.Forms.Application.ComponentManager.System.Windows.Forms.UnsafeNativeMethods.IMsoComponentManager.FPushMessageLoop(Int32 dwComponentID, Int32 reason, Int32 pvLoopData)
       於 System.Windows.Forms.Application.ThreadContext.RunMessageLoopInner(Int32 reason, ApplicationContext context)
       於 System.Windows.Forms.Application.ThreadContext.RunMessageLoop(Int32 reason, ApplicationContext context)
       於 System.Windows.Forms.Application.Run(ApplicationContext context)
       於 Microsoft.VisualBasic.ApplicationServices.WindowsFormsApplicationBase.OnRun()
       於 Microsoft.VisualBasic.ApplicationServices.WindowsFormsApplicationBase.DoApplicationModel()
       於 Microsoft.VisualBasic.ApplicationServices.WindowsFormsApplicationBase.Run(String[] commandLine)
       於 WindowsApplication1.My.MyApplication.Main(String[] Args) 於 17d14f5c-a337-4978-8281-53493378c1071.vb: 行 81
       於 System.AppDomain._nExecuteAssembly(Assembly assembly, String[] args)
       於 System.AppDomain.ExecuteAssembly(String assemblyFile, Evidence assemblySecurity, String[] args)
       於 Microsoft.VisualStudio.HostingProcess.HostProc.RunUsersAssembly()
       於 System.Threading.ThreadHelper.ThreadStart_Context(Object state)
       於 System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state)
       於 System.Threading.ThreadHelper.ThreadStart()
  InnerException:
Message 1 of 8
(7,006 Views)
May I know your version of VB.NET?
version of Measurement Studio?
OS ?
Message 2 of 8
(6,980 Views)
os:windows xp sp3
Microsoft Visual Studio 2008
Measurement Studio 8.6
Message 3 of 8
(6,975 Views)
Message 4 of 8
(6,953 Views)
The same exception was thrown in my application when I've worked with ScatterGraph.
One can chose ScopeChart mode instead StripChart for problematic axis (usually  x axis). Using this mode, the problem is avoided. Or, if you create your graphs dynamically, you can recreate graph that was thrown an exception (actually, I recreate all graphs that are presented if exception is thrown). User can see a little flicker, and application continues to work.
"The software isn’t finished until the last user is dead."
Message 5 of 8
(6,550 Views)
我的mode為:AutoScaleLoose 請問要如何抓取ERROR
Message 6 of 8
(6,167 Views)
我已試到答案但不知是否正確,目前run都沒問題
 ScatterGraph1.Plots.Item(0).XAxis.Mode = AxisMode.AutoScaleLoose
 ScatterGraph1.Plots.Item(0).YAxis.Mode = AxisMode.AutoScaleVisibleExact
將mode改變一下就行了
Message 7 of 8
(6,162 Views)
跑久了還是一樣會出錯...不知道該如何解決了..
Message 8 of 8
(6,129 Views)
