WaveformGraph.PlotWaveformsMultiple
I can plot a single waveform using WaveformGraph.PlotWaveform, but I'm having difficulty formatting my parameters for WaveformGraph.PlotWaveformsMultiple.
I tried using the following code to accomplish this but I get a conversion error.
    AnalogWaveform<double>[] waveforms = new AnalogWaveform<double>[2];
    for (int m = 0; m <2; m++)
          double[] dblresult = (double[])waveformArrayList[m];     //waveformArrayList contains two 1D arrays
         AnalogWaveform<double> waveformCurrents = AnalogWaveform<double>.FromArray1D(dblResult);
         waveforms[m] = waveformCurrents;
   myWaveformGraph.PlotWaveformsMultiple(waveforms, plotOptions);
On my call to PlotWaveformsMultiple I get the error "Error 3 Argument '1': cannot convert from 'NationalInstruments.AnalogWaveform<double>[]' to 'NationalInstruments.AnalogWaveform[*,*]'.
I would appreciate help in getting my variable declaration syntax corrected (or whatever I need to do) to fix this.  I'm not familiar with the syntax [*,*] in a parameter of a method.  What does that mean?
(3,811 Views)
Hi SubseaFish,
The PlotWaveformsMultiple method accepts a 2D array of AnalogWaveform<TData> data and you are just passing in a 1D array of AnalogWaveform.  Since your are just wanting plot a 1D array of AnalogWaveform<double>, you can just ue the PlotWaveforms method.  That method accepts a 1D array of AnalogWaveform.
I posted a similar example to yours here where the only difference was I was using the FromArray2D method. Maybe that will help.
Best Regards,
Jonathan N.
(3,793 Views)
Thanks SO much.  I was so focused on the word "multiple" in the method name, I incorrectly assumed PlotWaveformsMultiple was needed in order to plot multiple waveforms.
(3,769 Views)
