Waveform Graph Auto Scale Property
Is there a way to select between auto scale and fixed scale from a waveform graph property node?
It is easy to find from the front panel properties, but I cannot seem to find it on the property node.
The goal is to allow the user to select a specific segment of a displayed waveform and enter min and max values for the scale.
Perhaps there is a better way to do this.
Cursors?
Any help is appreciated.
(4,283 Views)
You should probably post this question to the LabVIEW forum, since this one is for Measurement Studio .NET libraries.
Bilal Durrani
NI
(4,271 Views)
Oops, thanks.
How did I get here????  (is there an emoticon for "rhetorical") Smiley Surprised
(4,270 Views)
In the graph property node, go to the Xscale -> Scale Fit property.
I think that's exactly what you're looking for!
Best Regards,
JLS
Best,
JLS
Sixclear
(4,262 Views)
Thanks, I got the same thing from the LabView board (my bad posting it here).
Same question though, on the front panel graph properties, Auto Scale is a checkbox (implying a boolean, I would think).
On the block diagram properties, the "Scale Fit" property is numeric.  I would assume 0 is unchecked, but is that true?
(4,255 Views)
