WPF remove PointAnnotations from graph
Hi
I want to remove all my PointAnnotations in a graph. I have tried the code below but it doesn't work. Is there som other way?
/Axel
For i = 0 To sg.Children.Count - 1
If sg.Children(i).GetType = GetType(PointAnnotation) Then
                sg.Children.Remove(i)
EndIf
Next
(5,687 Views)
Accepted by topic author AxelHaraldsson
There are two issues with the code as written:
  • First, it is using the Remove method on ObjectCollection instead of the RemoveAt method (i.e. it is trying to remove the object i, not the element at index i).
  • Second, when you remove an element at index i, all the later elements in the collection effectively shift down one, but the For loop still increments i before checking the next element, skipping adjacent values.
When removing elements, it is best to iterate backwards over the collection to avoid index mis-alignment:
    For i = sg.Children.Count - 1 To 0 Step -1
            sg.Children.RemoveAt(i)
        End If
    Next
~ Paul H
(5,681 Views)
Thanks Smiley Happy
/Axel
(5,675 Views)
