WPF Graph Axes: Change ScaleKind at runtime
The following problem is very similar to this thread, but I'm looking for a solution that follows the MVVM pattern and doesn't change UI elements in the code-behind.
Scenario: I have a CheckBox element that, when checked, will change the value of a boolean called LogarithmicXAxis in the ViewModel. I want my Graph's x-axis ScaleKind property to respond by toggling between Linear and LogarithmBase2. So I wrote an IValueConverter class as follows:
class BooleanScalekindConverter : IValueConverter
    public object Convert(object value, Type targetType, object parameter, System.Globalization.CultureInfo culture)
        if ((bool)value)
            return NationalInstruments.Controls.RangeScaleKind.LogarithmBase2;
        else
            return NationalInstruments.Controls.RangeScaleKind.Linear;
    public object ConvertBack(object value, Type targetType, object parameter, System.Globalization.CultureInfo culture)
        if (value.Equals(NationalInstruments.Controls.RangeScaleKind.LogarithmBase2))
            return true;
        else
            return false;
Then I bound the ScaleKind property to LogarithmicXAxis:
<ni:AxisDouble x:Name="xAxis" Orientation="Horizontal" Range="-10, 10, System.Double" ScaleKind="{Binding LogarithmicXAxis, Converter={StaticResource BooleanScalekindConverter}, UpdateSourceTrigger=PropertyChanged}" />
When I try to debug, I can see that the LogarithmicXAxis value is updating correctly (and a different part of my app responds to a change in that value). However, there must be something wrong with the way I'm binding, or possibly with my converter, because the converter methods never get called.
I am relatively new to WPF, Measurement Studio, and MVVM, so any suggestions would be greatly appreciated!
(6,319 Views)
khawesdo,
What version of Measurement Studio and Visual Studio are you using?
Kirk L. | Applications Engineer | National Instruments
(6,241 Views)
Measurement Studio 2013  (v. 13.0.0.242)
Visual Studio Ultimate 2012
(6,239 Views)
Accepted by topic author khawesdo
Hi, khawesdo
I think your binding is almost there. You should do this (I've pasted the entire XAML for context, making the relevant parts bold, pardon my nasty namespace name Smiley Wink):
<Window x:Class="WpfApplication5.MainWindow"
        xmlns="http://schemas.microsoft.com/winfx/2006/xaml/presentation"
        xmlns:x="http://schemas.microsoft.com/winfx/2006/xaml"
        xmlns:ni="http://schemas.ni.com/controls/2009/xaml/presentation"
        xmlns:local="clr-namespace:WpfApplication5"
        Title="MainWindow" Height="480" Width="640" >
    <Window.Resources>
        <local:BooleanScalekindConverter x:Key="BooleanToScaleKindConverter" />
    </Window.Resources>
    <Grid>
        <ni:Graph HorizontalAlignment="Left" Height="200" Margin="0" VerticalAlignment="Top" Width="300">
            <ni:Graph.Axes>
                <ni:AxisDouble x:Name="xAxis" Orientation="Horizontal" Range="-10, 10, System.Double" ScaleKind="{Binding Value, Converter={StaticResource BooleanToScaleKindConverter}, ElementName=LogarithmicXAxis, Mode=TwoWay, UpdateSourceTrigger=PropertyChanged}" />
            </ni:Graph.Axes>
        </ni:Graph>
        <ni:Switch x:Name="LogarithmicXAxis" Content="Switch" FalseContent="Off" HorizontalAlignment="Left" Height="23" TrueContent="On" VerticalAlignment="Top" Width="100" Margin="22,231,0,0" Value="False"/>
    </Grid>
</Window>
Here, I am binding specifically to the LogarithmicXAxis element's Value property.
I hope that helps!
Daniel Dorroh
(6,202 Views)
