Vision Development Module and .NET
Two quections regarding the Vision Delopment Module 7.1:
1. Can I use the functions contained in the IMAQ Vision library both from C++.NET and C#.NET?
2. Does MStudio 7.1 (or 8.0) contain the Imaq Vision library as well?
Thanx in advance.
(3,759 Views)
Hi Costas,
I am actually writing an application using Imaq Vision 7.1 in C# and Visual Studio .NET 2005 and it works perfectly.
The only problem you will have is that there is no documentation on Imaq libraries for C#.
You have to go in the IMAQ VISION for VISUAL BASIC Reference to find all the Objects that are available for your application.
In you C# Solution, you have to Add Objects (CWIMAQ, CWIMAQVision, CWIMAQViewer, ...) and import them into your application form
Yours
Cécile
(3,752 Views)
Hi Costas,
Yes, you can use the Vision library with both C++ .NET and C# .NET.
Vision Development Module 7.1 and 8.0 include the libraries and ActiveX controls for using Vision in CVI or with Measurement Studio.
Allen H.
Message Edited by allen_h on 04-04-2006 02:19 PM
(3,732 Views)
