VB.NET - Access CW DAQ Library
Is there a way to access the CW Daq library functions
in vb.net without placing a control on a form?
Something like
Imports CWDAQControlsLib.CWDIOClass
'or
Imports AxCWDAQControlsLib.AxCWDIO
Public Class clsDAQ
Inherits CWDAQControlsLib.CWDIOClass
End Class
Public mydaq As New CWDAQControlsLib.CWDIO()
mydaq.Channels.Add("Channel1")
Curt
(6,706 Views)
Hi Curt,
By trying to dynamically load this control, you are sidestepping a few important steps.
First, This ActiveX control must have a certain number of initial references resolved before being used. This occurs automatically when the control is placed on your form. So you will see extensive errors when trying to call functions or set propertys for the control without first resolving these references. There is no published list of these references.
Secondly, you are bypassing the .NET environment's step of automated wrapper(s) generation for ActiveX components. You will notice that the CWDAQControlsLib and AxCWDAQControlsLib references are only visible in solution explorer after you add a control to the form. Without these wrapper DLL's, the
control is virtually useless in the .NET environment.
regards,
Eric Meyer
(6,706 Views)
