Usage of waveformgraph
I have tree question
Q1: I have seen a familiar disscusion on this topic earlier but this is not working the way I want.
I have a waveform graphic with pilar view. Where each pilar is one step on the xaxis. What i want is to use mousedown event to dynamicaly  mark one or more pillars.
and in this event collect wich xaxis that has been marked.
I have tried this one inside a plotareaMouseDown event without success:
NationalInstruments.UI.XAxis x = new NationalInstruments.UI.XAxis();
x = waveformGraphSpectrum.GetXAxisAt(e.X, e.Y);
What to do??
Q2: Is it possible to make maximum lines on each pillar inside the waveformGrap?
Q3: How do I avoiding the xaxis to be displayd as decimal digits with the same width on the graph view
With regards
Leif Gunnar
(3,451 Views)
Hi Leif Gunnar
If you want to retrieve the X and Y values that generated the event you should look at the following post:
http://forums.ni.com/ni/board/message?board.id=232&message.id=5899&requireLogin=False
To get the exact X values of the pillars you would probably have to round the X value to the closest pillar.
Best regards Øyvind Ø
(3,345 Views)
