USB-6501
I use a USB-6501 as a ground fault monitor in a system. At various times, the 6501 reports the fault 'A USB transfer failed due to a transaction error reported by the USB host controller.
Task Name: _unnamedTask<0>
Status Code: -50808'
To fix this, we have to USB unplug and replug the 6501. Restarting the application software does not fix the error.
The system runs 24/7. The fault occurs infrequently, is there anything that I can do in software to reset the connection?
Dave
(2,624 Views)
Hi Dave,
Unfortunately this can be a tricky problem to pin down. Some suggestions on where to look:
-If altering the hardware at the USB input end is an option, this article might be of help.
-In terms of resetting the connection in software I'm aware of this fix that is possible in LabView, however, I'm unsure of how this would be done in a text based language.
-This forum post goes over some other potential causes of the problem.
Jonah
Applications Engineer.
National Instruments.
(2,594 Views)
Thanks Jonah,
We have moved the 6501 USB direct to the PC instead of through a hub. Will let you know if this helps.
DC
(2,590 Views)
