Thermometer fill Problem
I am using Thermometer Control in my application with interaction mode DragPointer and SnapPointer Enabled. When I start my application and change the value of the control during runtime the fill is starting above the minimum division and ending below maximum division. How to set the fill area properly? pl help.
Vhavle
(4,309 Views)
Hi Vhavle,
This is a known issue. Unfortunately, we do not have a workaround. However, it will be fixed in the next version of Measurement Studio. You can track this issue with Issue ID: 360932. I apologize for the inconvenience.
(4,289 Views)
