TDMS file on disk doesn't get updated with AutoSave set to true when appending data to channels
Hello friends,
I am developing a WPF application that needs to log data to TDMS files. I append data to channels in the TDMS file periodically. The TDMS file's AutoSave property is set to true upon creating it (although I'm pretty sure true is the default value of this property).
With the AutoSave property set to true, I would expect to see the file's size grow in windows explorer as my application runs and appends more data to it however, this is not what happens. In fact, the TDMS log files don't get updated until the application is gracefully shutdown. If I don't gracefully shutdown my application (clicking exit button in upper right hand corner) and I stop the debugger from visual studio, the TDMS log files remain at 0KB.
Why aren't my TDMS files getting saved to disk as my application runs, even though AutoSave is set to true?
Below is my class responsible for writing data to TDMS files. The WPF application calls one of the AppendData() overloads periodically. The CreateNewSegmentInLogFile() function is called once at application startup.
internal class TdmsFacade : ITdmsFacade
        private string _latestChannelGroupName;
        private readonly TdmsFile _logFile;
        internal TdmsFacade(ITdmsData data, string filePath)
            // Initialize various file options for accessing tdms files.
            var tdmsRwFileOptions = new TdmsFileOptions
                Access = TdmsFileAccess.ReadWrite,
                FileFormat = TdmsFileFormat.Version20,
                BufferingDisabled = true
            // Assign initial properties to log file & create it.
            _logFile = new TdmsFile(filePath, tdmsRwFileOptions)
                Author = data.Author,
                Description = data.RootDescription,
                Title = data.Title,
                AutoSave = true
        public void AppendData(double[] samples, TdmsChannelEnum channelToLogTo)
            // Get the channel group.
            var channelGroup = _logFile.GetChannelGroups()[_latestChannelGroupName];
            // Get the channels.
            var channels = channelGroup.GetChannels();
            // Append data to the channels.
            switch (channelToLogTo)
                case TdmsChannelEnum.ChannelZero:
                    channels[0].AppendData(samples);
                    break;
                case TdmsChannelEnum.ChannelOne:
                    channels[1].AppendData(samples);
                    break;
                case TdmsChannelEnum.ChannelTwo:
                    channels[2].AppendData(samples);
                    break;
                case TdmsChannelEnum.ChannelThree:
                    channels[3].AppendData(samples);
                    break;
                default:
                    throw new InvalidOperationException("An invalid channel chosen to log to. A channel will be considered invalid if it is not utilized by the DAQ.");
        public void AppendData(double sample, TdmsChannelEnum channelToLogTo)
                    channels[0].AppendData(sample);
                    break;
                    channels[1].AppendData(sample);
                    break;
                    channels[2].AppendData(sample);
                    break;
                    channels[3].AppendData(sample);
                    break;
                default:
        public void CreateNewSegmentInLogFile(ITdmsData tdmsData)
            // Add a new channel group.
            var now = new DateTimeProvider().GetDateAndTime();
            _latestChannelGroupName = now.ToString().Replace('/', '_').Replace(':', '_').Replace(' ', '_');
            var channelGroup = _logFile.AddChannelGroup(_latestChannelGroupName);
            foreach (var property in tdmsData.ChannelGroupProperties)
                if (property.DataType.Equals(TdmsPropertyDataType.DateTime))
                    property.Value = now;
                channelGroup.AddProperty
                    property.Name,
                    property.DataType,
                    property.Value
            // Add channels to the new channel group.
            foreach (var channelInfo in tdmsData.ChannelInformation)
                var channel = channelGroup.AddChannel(channelInfo.ChannelName, channelInfo.DataType, channelInfo.ChannelDescription, channelInfo.UnitString);
                // Add the properties.
                foreach (var property in channelInfo.ChannelProperties)
                        property.Value = new DateTimeProvider().GetDateAndTime();
                    channel.AddProperty(property.Name, property.DataType, property.Value);
(3,657 Views)
Can you provide version numbers for any relevant software/driver/api versions you are using?
(3,616 Views)
Could you also humor me by setting BufferingDisabled to false and noting any changes in behavior?
(3,606 Views)
Can you provide version numbers for any relevant software/driver/api versions you are using?NationalInstruments.Tdms.dll Version=15.0.45.49153
The version of the NationalInstruments.Tdms.dll I am referencing is 15.0.45.49153.
Sure, setting BufferingDisabled did not change the behavior. The .tdms file still doesn't get written to until the application is closed.
(3,589 Views)
Accepted by topic author b!tmaster
That is unfortunate, I was playing around with this setting recently and found that setting BufferingDisabled = false unexpectedly caused AutoSave to work properly.
It seems that this may be a bug and there is an open corrective action request (CAR) for it: 643616
I recommend you check the readme of future releases to see if that number is listed among the bug fixes.
(3,582 Views)
brettski,
Thanks for the info. I will keep my eyes peeled for any information.
(3,577 Views)
I have confirmed that setting BufferDisabled to false allows the AutoSave feature to work properly, strange!
(3,463 Views)
